iPod and iTunes
Discussion in 'Headphones, Earphones & Portable Music' started by rnsdm001, Mar 18, 2005.
Tags:
  1. rnsdm001
    rnsdm001
    Hello
    Myself and girlfriend are wanting to buy an ipod.
    Now I dont know much about the whole iPod thing. I do know that iTunes exists, where you can purchase albums and singles and drag them onto your iPod.
    But isnt iTunes MP3 files? So can I download MP3 files from other sites or am i restricted to using only iTunes
    Thankyou :lease: :lease:
  2. davehk
    davehk
    Oct 17, 2003
    711
    28
    London
    +45
    I think Itunes will only download from Itunes store over the Net.
    But Itunes allows you to add any mp3 file to the library and download it to your Ipod.
  3. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,368
    41
    Tunbridge Wells
    +12
    Downloads from iTunes are in AAC format, which is mp4. I think nearly all other download services use Restricted WMA format. I'm not sure if this is compatible with the iPod.
    I personally would either buy the CD itself or use the iTunes music store to download.
  4. mick's cat
    mick's cat
    Itunes is able to use AAC (which is MP4), MP3, AIFF, WAV, ALAC files. On the PC it can also import WMA files (it converts them to one of the above formats of your choice).
    So files you download from the internet (usually MP3) will generally work. Files in other formats iTunes doesn't use can usually be converted to formats iTunes does use (with third-party utilities). The exception to this is files that are in WMA from paid download sites (these are DRM files, so cannot be used by iTunes).
    Files downloaded from the iTunes Music Store are all in AAC format.
    Here endeth the lesson... :lesson:
  5. rnsdm001
    rnsdm001
    so am i understanding this correctly:
    * I can download any mp3 file to my ipod
    * From any internet site
    I can still have libaries on itunes right?
  6. davehk
    davehk
    Oct 17, 2003
    711
    28
    London
    +45
    Yes - it shouldn't matter where the mp3 file comes from, once it's on your PC you can add it to the Itunes library and it will be downloaded to your ipod when you sync up (or you can do it manually if you have turned off auto-sync).
    No different from ripping a CD using, for example, EAC or MM Jukebox, and then adding it to Itunes and downloading to Ipod.
  7. rnsdm001
    rnsdm001
    superb - thanks dave
