iPod and iPhone on iTunes?
Discussion in 'iPhone Forum' started by turbohat, Jun 17, 2009.
Tags:
  1. turbohat
    turbohat
    Nov 7, 2004
    330
    +3
    Can anyone help?
    What is the simplest and most idiot proof way to have an ipod and an iphone on the same itunes on the same computer?
    Ideally I'd like to sync my ipod as normal (30Gb) with selected files from my iTunes directory (80ish Gb) and the odd selected file onto the iPhone (16Gb)
    Thanks in advance
  2. Aweb
    Aweb
    Dec 5, 2005
    361
    Yeovil, Somerset
    +20
    it should just work...
  3. chic
    chic
    Jul 1, 2001
    5,985
    glasgow
    +871
    the easiest way to do it is to create a new itunes library, thats what i do and i can sync both my ipod 80gig and iphone 16gig on the same computer.
    To do this just hold down the shift key when starting itunes and it should give an option to choose or create a library, just create one and call it "iphone" and then copy what music you want into this library from your main itunes music folder. Just make sure you have the correct itunes music folder selected before connecting your ipod or iphone or you will do what i did when i connected my iphone whne it was on the ipod livrary and it started to copy everything from my ipod onto my iphone.So when you want to sync a device just hold down shift when starting itunes and selct the library you want to use.
  4. ADC
    ADC
    Jan 5, 2004
    1,876
    48
    Coventry
    +60
    I have my i-phone and my daughters shuffle set up on my itunes. My daughters is set to sync with only her playlist in itunes. Any new songs she adds she simply adds them to her playlist and then syncs the shuffle. I do the same on the i-phone. Its set only to sync music from my playlists.
  5. paulmcg
    paulmcg
    Feb 5, 2005
    142
    Reading
    +12
    I sync both my IPod and Iphone from the same library. Do the following
    Create a playlist call eg. Ipod and another called IPhone.
    Connect the Ipod - clik the ipod when it comes up and move to the Music tab in the main window. click "sync only the following playlists" and select Ipod.
    follow the previous step for Iphone.
    Add the tracks you want to the Ipod playlist and add the tracks you want to the Iphone playlist then sync both.
    Paul
  6. Dinger164
    Dinger164
    Sep 23, 2006
    28
    3
    Hi there, have created a new Library called iphone, which is obviously empty. However when starting itunes now it go's straight to this library and I cannot seem to find a way to reopen my normal Library?? Please forgive me for being stupid but can somebody explain to me how to get back to my original one?? :oops:
    Dinger
  7. chic
    chic
    Jul 1, 2001
    5,985
    glasgow
    +871
    hold shift when starting itunes and it should give you the option of choosing a library, then just select the otherone which will probably be called itunes.
  8. CrispyUK
    CrispyUK
    Jul 2, 2006
    57
    +3
  9. andrewrunagall
    andrewrunagall
    Sep 4, 2005
    1,162
    Hadleigh, Essex
    +63
    The way I keep my iPhone 3G and iPod Touch separate is to use playlists. And then just pick 'n' choose music and videos that way.
    I probably got the OP's question all wrong, but it's how I do it.
  10. Dinger164
    Dinger164
    Sep 23, 2006
    28
    3
    Thanks for that, had to go up a folder to find my original itunes. Was having a UTS moment (User Too Stupid) Sorted now.
    Dinger
