ipod 20gig
Discussion in 'Headphones, Earphones & Portable Music' started by saunders494, Jan 5, 2005.
Tags:
  1. saunders494
    saunders494
    I needed to wipe my pc hard drive to clear a problem and had all my songs on it for my ipod. I followed some apple guidance on using the ipod as a hard drive. I then reloaded all the tracks on the pc and they are in my library but now I cant play any of the tracks in my library or update the ipod automatically or manually as I am "unauthorized on that pc" ???
  2. cyberman
    cyberman
    if you are unauthorised, you should just be able to enter your Apple ID and password and it should authorise the PC for you.
    Dan
