iplayer , itv hub , more 4 apps not working?
groggy
Hi all
The other week my streamimg apps stopped working after an update i had to to get plex to work.
They load up but will not play any video
Now none of them show in the appstore either when i search them?
Does anyone know whats happening??
Groggy
JayCee
Have you tried unplugging/switching off at the mains power socket for an hour or so?
It would also be helpful if you told us what model of TV?
groggy
hi
yes. its gets switched off at the mains every night really.
model number is :
TX-49FX740B
JayCee
I've seen reports of similar symptoms being cured by rebooting the router as daft as it seems so try that.
groggy
Rebooted router.
Now connected via ethernet cable but still same.
Network connection is all OK and connection to Internet was successful........but still the apps load and all the menus and different programmes show up but will not play any video?
Kapkirk
I had a similar issue like this with my Panasonic HZ2000, It turned out to be the privacy settings,
Don't know how to get into your settings but on mine it is: Setup - Data Service Application - Privacy Setting. Try reset and turn privacy setting to LOW.
