ipl sub, any good ?
C
chris thomas
Could anyone please tell me if they have tried the ipl acoustics self assembled subwoofer which is advertised in hcc.
200w amp, down to 25hz for £271.
Claiming to match if not better award winning subs of around the £800 price bracket. Cheers chris t.
J
Jagular
Originally posted by chrisyt:
<STRONG>Could anyone please tell me if they have tried the ipl acoustics self assembled subwoofer which is advertised in hcc.
Claiming to match if not better award winning subs of around the £800 price bracket. Cheers chris t.</STRONG>
Hi chrisyt,
I've built an IPL SW2 kit and yes it's brilliant!
It goes down to 20Hz when run-in, NO-PROBLEM!!!
Hi quality too! The sound it produces is tight and follows pulses of low bass very accurately suiting home Cinema and Hi-Fi use.
I needed a bit of encouragement to make the initial decision, but I’m glad I did now.
If you can put your hand to bit of DIY, then I don’t think you will be disappointed.
Jagular
philmate
Hi ,
If you can put together a MFI or Argos flatpack then this sub will be no problem, its added no end of LFE fun to my DVD,s and music is just as good. £285 all in and a bit of diy... or £800 to a shop..don't create your own fear ...go for it, you won't be dissapointed.
Philmate
Ken
The IPL sub is definately a worthwhile purchase. Do a search for IPL Sub, for lots more info. Good luck.
Ken
[ 22-04-2001: Message edited by: Ken ]
C
chris thomas
Cheers lads, thats all i needed to know, i,ll get one.
Similar threads
Podcast: LG SN7CY Soundbar Review, Hisense 55U7Q, LG Nano90, Best of the Month, B+W Sigourney Weaver
