Iphone Thinks Headphones are Still Plugged In
Discussion in 'iPhone Forum' started by Rock Da Bass, Sep 8, 2012.
Tags:
  1. Rock Da Bass
    Rock Da Bass
    Jan 27, 2002
    5,795
    EU
    +822
    This is possibly a common problem and has been asked a million times before but I couldn't find it in a search.
    My iPhone (4S) seems to think the headphones are plugged in, eg when I put the volume up or down it assumes it's the headphone volume.
    This means I'm not getting any sound from apps but more importantly I can't hear anything whilst making a call.
    There'all sorts of half useless info from a quick Google but I thought this was a more useful place to ask for help.
    I've switched the phone off and on several times and plugged/unplugged headphones several times.
    There doesn't seem to anything in the socket to give a false reading.
    Is there a quick fix to this problem or should I just take a trip into town and pass my phone to the good folks at the Genius Bar?
    Thanks for any help or replies.....
  2. kalgar
    kalgar
    Jun 20, 2006
    573
    46
    +244
    Is it damp in headphone socket as that causes that problem try a hairdryer in socket if it may be
  3. Rock Da Bass
    Rock Da Bass
    Jan 27, 2002
    5,795
    EU
    +822
    The problem seems to be going away a bit (is now intermittent) which suggests it probably is something to do with dampness now drying.
    Now I think of it, I think it has probably got slightly wet recently as I use a cycling app a lot and have got caught in the rain a few times recently.
  4. bpsmith
    bpsmith
    Jan 8, 2010
    7,572
    +709
    Time to invest in a LifeProof waterproof case, or similar, I think.
  5. dudemonkey
    dudemonkey
    Jan 14, 2013
    2
    Yayyyyy ! ... I have JUST had the same issue... and it WAS moisture ... well as I was out in the snow earlier it must have been from that ! ... got some loo roll, twisted it and put it in the headphone socket. twisted it round a few times and removed. repeated several times and hey presto ! Thanks peeps, you have saved my bacon x
  6. dudemonkey
    dudemonkey
    Jan 14, 2013
    2
  7. readymix
    readymix
    Jan 26, 2006
    361
    Knottingley
    +4
    Put it in some rice and it will be ok the rice takes out the moisture.
  8. Curly99
    Curly99
    Dec 29, 2006
    9,426
    +2,255
    Thread moved
    Curly
