Iphone resets while watching movies
johnrs
Hi There
I have converted a movie to play on my iphone and while it will play after a while my iphone will reset
Is this a know bug or something wrong??
Any input would be great
scudder
Yip something is wrong with your setting when you converted the movie, try a lower frame rate/bit rate and you should be fine. Your processor isn't coping with whatever settings you recorded the movie at.
johnrs
Thanks. Will give that a shot
kmkr03
What software did you use to convert the movie? If you're on a mac, isquit is quite good and it's free!
