iPhone photos gone missing, pls help!
Uresmane
Ok, so i has trying to do a photo and other stuff backup from my old iPhone to a pen drive . I had iTunes on it, i don't know what i clicked but i think i clicked something and now for some reason some of my photos and others stuff are missing. I don't know where it is. I don't remember well what happened but think i clicked on the return button and said if i quit some files might be removed but i thought it was some files that i did backup on the PC. I remember i did a backup hours ago. Can someone pls help this is very serious.
John7
In iTunes, restore,the phone from the last backup you did (if it was before you deleted the files).
It makes it even easier if you were to have used iCloud for backups. I would really recommend to do that opposed fo doing this manually.
Uresmane
In iTunes, restore, the phone from the last backup you did (if it was before you deleted the files).
When I try to do that every time it says that an unknown error occurred (-42), so I can't do the backup. But even if the files are gone I THANK myself for archiving these files on my CDS
The Best Movies and TV Shows Coming To Amazon Prime Video in August 2020. Tom's Thumbs.
