Iphone email problem. Unlocked on voda
jmsjabb
Established Member
I have a NZ unlocked iphone 3g and have been running it on Voda for a year now. I have recently noticed when I send email throung my server it goes just like that on wifi. It will not go on vodafone when out of wifi range. ( It says something about the email address rejected by the server )
I think my fone was updated to vodafone settings a short while ago as it now says Vodafone in full where as before the Vodafone would "scroll" in and out.
Any ideas?
sct21
I had the same problem, would not send emails when away from wifi.
Try this, as it worked for me
One thing I did have to do was change the Primary and Other servers around;
Select settings,
Select Mail, Contacts, Calendars,
Select mail account you want to edit,
Scroll down to SMTP,
In here you can see it lists a "Primary server" and "Other SMTP servers"
I turned Primary server off
I added a SMTP server under "Other SMTP servers" as send.vodafone.net
This took a while to come back with a response about not using SSL this SMTP server doesn’t support SSL. after I selected this it added itself,
I ticked this new SMTP server on, Tested and success
Hope this helps
jmsjabb
Established Member
Select settings,
Hope this helps
Sorry, do you mean say yes to SSL or no?
Amazon Fire TV Cube Gen 3 Review: Coming Soon
