Iphone Controlled Wifi LED Bulbs
wysinawyg
Only reference I could find to them anywhere was on a Philips Hue forum where the view seemed to be they weren't that bright and were on a proprietary protocol unlike the Hue (where its hoped third parties will join in with compatible stuff).
Also seems quite directional light from the videos (although I think a lot of LED bulbs are) so no good if your fitting point up but you want the light below.
Wahreo
Anyone tried these?
Also seen these as I'm looking for a quick and cheap solution for my hallway. Don't really want to spend £50 on a hue lamp.
Auraglow Colour Change Bulb
Edit: I've since found out that the link is the same lamp as the cheap eBay type.
