iPhone 6s Plus Car Holder
W90WBA
Need a new car holder for my 6s Plus, thought I'd create this thread to see what others are currently using
KyleS1
Spigen stealth is good, especially for the plus as it works in landscape mode.
bransoj
Seem to remember a similar thread on here before when the 6 Plus was released, suspect if you search you will find it, and a lot of folk were going for these or the many eBay cheaper versions of :-
Kenu
KyleS1
I tried the Kenu before the Spigen but it snapped my vent grill :(
W90WBA
How do you find it using in landscape? I only ever usually use horizontal and usually opt for a Brodit holder
KyleS1
It works great in landscape but I don't have the plus, so it's annoying!
W90WBA
Will have a look in my car tomorrow see if theres a suitable place to possibly put the holder. Not a fan of those that go on the vent
W90WBA
I've had brodit for the last 3/4 phones I've had, usually around £40 but never had a single problem and phone has always felt very secure
W90WBA
Due to the layout of my car I can't use the Spigen holder so still on the market for something else
W90WBA
BMW 3 Series the below image is pretty much what mind looks like on the inside
W90WBA
Yeah that's what I usually have tbf, just thought I'd see what else was available
Only issue is with having Plus not sure how easy it'd be having the phone to the right of the steering wheel
paulyoung666
Won't help you but I have my S6 edge down by the gearlever in my kuga , works great but then I am left handed ....
W90WBA
I usually prefer having it to the right of the steering well tbf, 1 as I'm right handed and 2 as it means my eyes are still on the road and quick glancing at my phone doesn't mean completely removing my eyes from the road
richard plumb
I have the same car and have been using a kenu airframe+ on the vent just to the left of the steering wheel. Seems sturdy enough and a good position to see it clearly.
PFML84
That looks interesting. I have a 6 Plus and want to find a way of mounting it in my Mk6 Golf that isn't too low down and not attached/blocking one of the vents as I keep hearing horror stories of those Kenu Airframe ones breaking the vent slats. Do you have any pics of yours installed and in action? Can it be installed and then pivoted to have the phone facing the driver no matter the position? Is it easily turned from landscape to portrait? Does it feel sturdy and secure when holding the phone whilst driving over say speed bumps etc. where the whole car moves?
Lyn2012
When I am in the UK I use this mount and find it very good, asnearly as stable as a Brodit even over speed bumps and much better than the Kenu style mounts I have also tried. It can be installed and then pivoted, there is a ring you can easily loosen while it is installed that lets you swivel the phone to the exact angle you prefer, see below. I have had no problem when going over even the biggest speed bumps with my IP6 Plus and now the 6S Plus. I am abroad at the moment and driving a Citroen C4 which has the CD slot very low down making it difficult to see the screen and the road as well as my flip case interfering with the gear stick. This is why there is a Brodit mount installed as well - this only arrived yesterday. Hope this helps.
PFML84
It looks like it would work great, just that the part that goes into the CD player looks very small and would appear to not have much anchorage. It looks like it could come out very easily or fall forward with the weight of the phone on it. Perhaps it's just me, but that's how it seems!
Lyn2012
I assure you it is firmly secured in place and doesn't feel at all unsafe when holding my iPhone 6S Plus in a Vaja leather case. I have used it in 2 cars now and it has never come loose, either from the CD slot or the phone from the mount. In my opinion the mount itself is very solid and well made, not a flimsy piece of plastic like I was half expecting it to be. Anyway, here are some more photos, and of course if you buy from Amazon and aren't happy, you can always return it. I have tried every type of mount available, and for me the two that stand out from the crowd are the Brodit and this one.
PFML84
I've just ordered one so I will give it a try and see how it goes. Thanks for your help.
Podcast: CES '22 TV Announcement Round-up, Plus, Most Anticipated Movies of 2022 and More...
Latest News
Philips unveils A7507 TWS headphones and new rugged outdoor speakers
  • By Andy Bassett
  • Published
Philips FB1 soundbar will use Fidelio wireless platform
  • By Andy Bassett
  • Published
Philips announces OLED807 and 8807 The One TVs for 2022
  • By Andy Bassett
  • Published
Lenco launches 400 series turntable and speaker combo
  • By Andy Bassett
  • Published
AVForums Podcast: 26th January 2022
  • By Phil Hinton
  • Published
