iPhone 5 Hotspot using hotel wifi?
Discussion in 'iPhone Forum' started by waynehayes, Aug 4, 2013.
Tags:
  1. waynehayes
    waynehayes
    Dec 14, 2007
    99
    +5
    Not sure if this is possible? I'm going away in a couple of weeks, and the hotel charges per device for wifi. I'd like to use my jailbroken iPhone 5 as a hotspot using the hotels wifi. Am I right in thinking that hotspots only work with cellular data?
  2. chukwe
    chukwe
    Aug 15, 2009
    5,136
    Welling, Kent
    +465
    The hotspot uses the wifi data if it's available otherwise it uses you cellular data
  3. bprentice2010
    bprentice2010
    May 23, 2010
    769
    46
    Banbury
    +126
    The wifi hotspot will use your cellular data.
  4. rjkgr
    rjkgr
    Aug 21, 2013
    165
    +6
    i have wifi for my jailbroken one and it sometimes doesnt connect... i think its because your lte is faster than there connection
  5. shopper150
    shopper150
    Dec 28, 2002
    632
    28
    +31
    From what I have tried, you can only hotspot from cellular, not from wifi
  6. waynehayes
    waynehayes
    Dec 14, 2007
    99
    +5
    Thanks for the replies. PDANet on Cydia did the trick. It can broadcast wifi or cellular data too.
