Quantcast
iPhone 4S with iCloud
hybridtheory
As per TV ad:
When I take photos or download music on my iPhone 4S they dont appear on my iMac until its sync'd with my iPhone 4S. What have i done wrong or setup incorrectly?
Baz
hybridtheory
MC77
Hmm, I know what you're getting at. I mean my stuff works (Have 2 iPhones, one iPad and one Mac) and doesn't need any interference from me to get it to work as it should, just sometimes it takes a bit of time that's all. For example, the other day I took a batch of photo's on my phone in my living room, walked to my Mac in the bedroom and it was all there in Photostream, but then today I took some photos and almost 2 hours later I got home and they weren't there, but an hour after that had appeared.
However, anything I download via the phone's or iPad, are always immediately downloaded on my Mac without fail. The bookmarking between the phone's and the iPad works a treat as well.
gkpm
As MikeCleal said sometimes it can take a bit of time.
Other than that check on your iMac that you have:
1) enabled Photo Stream on your iMac's System Preferences > iCloud
2) iTunes set to automatically download purchases in iTunes > Preferences > Store
Kev12
Made the mistake of renting an iTunes film on my phone, thinking it would also be on the iPad, no joy.
It obviously doesn't work for movies.
hybridtheory
I will have to check the settings on my iMac on Tuesday evening when I get back home.
Baz
bukem
You did not mention what version of iPhoto you have. I think it's iPhoto '11 that has the Photo Stream feature.
hybridtheory
I do have iPhoto 11.
Baz
hybridtheory
Now that I'm back home, Ive resolved my problem. Photo Stream hadn't been enabled on iPhoto :face palm:.
Baz
Similar threads
