Quantcast
iPhone 4S/iPad 2 to PS51D8000 Samsung TV
Downinja
Wanting to show my iphone photos on my TV, I figured this would be incredibly easy but I can't see how to do it.
Any help?
RobM
Or an AppleTV if you fancy going for a wireless solution. More expensive, but more feature packed too.
Downinja
There are some DNLA/uPNP apps that could work if you have your TV connected to the network.
Just not sure which one is better as I only ever used them for music. Try this one which is free:
AirAV
AirAV for iPhone 3GS, iPhone 4, iPhone 4S, iPod touch (3rd generation), iPod touch (4th generation) and iPad on the iTunes App Store
The DNLA solution is definitely more what I am looking at.
I tried with MediaConnect but couldn't get it to work will try airav later. Thanks.
Edit- Scratch that, it's the wrong way around, AirAV is a DLNA Player, I am more after a DLNA server for the iphone.
gkpm
Oops sorry misread the app's description.
Try iMediashare, it has mixed reviews but works on my Panasonic.
Similar threads
