Quantcast
Iphone 4 Home Button Problem
rahulp
I was wondering if anyone new any cheap services that will reapir the home button for my iphone 4, its reallyh unresponsive and have to press hard about 6 times for it work.
williamus
Try a search for Home Button in this forum. There are several workarounds for this problem - one of them might work for you.
spencer_uk
there is a workaround where you
1) go to an apple stock application (e.g. Weather)
2) hold the power button until you see "Slide to power off". Let go of the power button
3) once you see this - press and hold the home button until the main screen is displayed again.
Apparently this reconfigures the sensitivity of the button.
williamus
Similar threads
