TheBaldOne
Hi all!
I've had an iPhone since Jan this year and it's always been unlocked (for T-Mobile UK) using yellows0w (or ultrasn0w since OS3's release).
When I was using yellowsn0w EVERYTHING on the phone worked perfectly with no resets/signal dropouts but if I turned on 3G then it all went wrong with random signal dropouts and lost calls etc.
Since the upgrade to OS3 and ultrasn0w EVERYTHING including 3G signal has worked
but last night (29th Sept) the problems I suffered with yellowsn0w (signal dropouts when having 3G enabled) have started again... I've not changed anything settings-wise, I haven't re-synced with iTunes or updated any firmware by mistake.
Have T-Mobile UK suddenly changed frequencies or access settings does anyone know? There has been no changes at my end, just consistent "searching..." messages then an edge signal for 4-5 seconds then nothing again!
I went for 2-3 months with full 3G signal working brilliantly and now i'm back to my old yellows0w problems
Is anyone else suffering the same or can anyone shed light on my problem?
Many thanks for your help guys!
