Iphone 2g battery - how long does it/should it last?
Discussion in 'iPhone Forum' started by Stampax, Jun 11, 2009.
Tags:
  1. Stampax
    Stampax
    May 6, 2005
    1,441
    Northampton
    +90
    Quick questions - i'm looking to sell my old iphone 2g, but am concerned the battery may be less than brilliant. Talk time seems pretty good, and when not being used it lasts fine, but an hour of video watching or internet surfing will proably drain half the battery. Is this normal?
    Listening to music drains it too, though not quite as bad as this.
    I dont want to sell it to someone only for them to complain a few days later!
  2. wynnwillo212
    wynnwillo212
    May 14, 2009
    3,798
    Liverpool
    +114
    The iphone 2g battery is crap any way. They are fine if you are ringing or just leaving it switched on but if you are on the internet or playing games it will drain very very quickly
    Hope this helps :smashin:
  3. Stampax
    Stampax
    May 6, 2005
    1,441
    Northampton
    +90
    Cool, suggests mine isnt broken as such, just normal. Makes it easier to sell!
