Ipaq on internet.
Discussion in 'Home Cinema Control & Remote Controls' started by Baggy69, Jan 3, 2004.
  1. Baggy69
    Baggy69
    Mar 15, 2002
    189
    Birmingham, UK
    +3
    Hi, i have a ipaq 5450 with built in wifi and i have my home internet on a wifi router so i want to connect the ipaq up so i can play on the internet downstairs. Ive been able to connect the ipaq to the wireless network but when i try to go on internet explorer it just says page not found? Has anyone any ideas of how to do this or does anyone know of a website with an idiots guide to it??? Thanks Ian.
  2. morphman
    morphman
    My 5450 works dine once I have connected to the wireless router.
    Make sure you have your internet explorer settings pointing to the same connection as the wireless connection and it should work.
    I am using a wireless access point/router/dsl combo.
