Ipaq 4150 wireless issue
Discussion in 'Mobile Phones Forum' started by Gordon @ Convergent AV, Aug 14, 2004.
  1. Gordon @ Convergent AV
    Jul 13, 2000
    14,216
    +3,071
    Hi and HELP!
    My Ipaq lost all its memory after powerng down for a few days and I had to load back in TomTom etc. However a weird side effect seems to be that it's wireless lan seems to not be there anymore....I can do a test of the card and it says it is functioning but I cannot get it to detect my wireless network or to even appear to be on? (flashing green light etc) Blue tooth crap is all there but couldnt care about that.
    So anyone got a clue how to fix thiis before I smash it with a hammer....
    Cheers,
    G :lease:
  2. jont
    jont
    Apr 8, 2002
    4,300
    near Aylesbury
    +559
    I had to re-enter my network connection setings when mne powered down ... also lost tom-tom app so next time i installed on the same card as the maps ...
    Jon
  3. Rob.Screene
    Rob.Screene
    Sep 29, 2001
    1,329
    Berks, England
    +152
    Gordon,
    Could it be your wireless network is running WEP encryption and you've forgotten to enter the key or perhaps set the
    Shared mode in the wireless net work criver advanced type screens?
    cheers,
    rob.
  4. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,149
    41
    NW London
    +18
    try a soft reset if you havnt already. My 5550 did the same once but after a crash not after a power down. Do you get any lights when turning on the wifi? With mine if wifi is on i get orange if its connected i get green... If nothing after a soft reset then may need a hard reset. If you get orange but no green then its a settings problems...
