Ipaq 2210
Discussion in 'Mobile Phones Forum' started by Dave777, Aug 15, 2003.
  1. Dave777
    Dave777
    Oct 25, 2002
    479
    Gatwick
    +8
    Has anyone got/tried the new ipaq 2210. It looks just what I want with SD and CF sockets and bluetooth built in. Just need to add a wi-fi card and its spot on. Also the remote control software is built in and I've heard its OK. Is it? Does anyone know if it will understand pronto ccf's?
    Dave
  2. Amjad
    Amjad
    Aug 16, 2003
    7
    3
    Oldham
    Hello,
    I bought the 2210 about a month ago mostly for GPS but I do use it as a remote control.
    The built in nevo software is good as long as your device is listed or you have the device codes, there's no facility to learn from another remote. Nevo doesn't use CCF files.
    I've bought PDAWin for this and the new version 5.5 works great, haven't tried CCF mode yet, thought they looked a bit complicated! :)
    Regards,
    Mo.
  3. Dave777
    Dave777
    Oct 25, 2002
    479
    Gatwick
    +8
    That's great. if PDAwin works OK then problem solved. CCF's drive me batty too sometimes!
    Thanks.
    Dave
  4. HMHB
    HMHB
    Nov 11, 2001
    25,516
    Nottinghamshire
    +3,852
    Is there anywhere I can see a list of supported devices ?
  5. AOD
    AOD
    Feb 7, 2001
    707
    London
    +4
    Also what's the range like on the IR emitter? Does it have the "long range" infrared capability of other models such as the 3970?
    I'm looking for the cheapest way to get decent IR performance (for remote control purposes) and wireless lan connectivity so I can surf the net. Dell Axims don't fit the bill as I don't want to have to swap CF cards to access the net.
  6. HMHB
    HMHB
    Nov 11, 2001
    25,516
    Nottinghamshire
    +3,852
    Can anyone with one of these confirm that it works OK as a remote control ? If so I think I'll get one
  7. HMHB
    HMHB
    Nov 11, 2001
    25,516
    Nottinghamshire
    +3,852
    I've been doing some searching around and found this
    Ipaq 2210 review
    There are link off this page to a handhelds forum. It appears it has a "cosunsumer-grade Ir" and I've seen quotes from people in the forum that it works up to 50 feet. It also has learning capabilities so I think I would be happy with this as a remote.
