ip address failed
Discussion in 'Xbox Forums' started by bigheck, Dec 27, 2006.
  1. bigheck
    bigheck
    Dec 27, 2006
    11
    I bought an Official XBox 360 Wireless Adaptor but when i try to connect it says that the ip address has failed i am using a bt voyager 2091 wireless router. xbox live connects perfect when i use an ethernet cable could someone :lease: help thanks
  2. Member 79251
    Member 79251
    Jul 2, 2005
    13,421
    +2,187
    What ip settings are you using ?
  3. bigheck
    bigheck
    Dec 27, 2006
    11
    ip settings are
    automatic
    ip address
    169.254.227.181
    subnet mask
    255.255.0.0
    gateway
    0.0.0.0
  4. ShadowmanUK
    ShadowmanUK
    Feb 14, 2006
    1,299
    63
    +132
    Its not getting a proper IP Address from your router then. You need to check your router settings to see if there's a "Client List", or "Wireless station" list.. they are called different things on different routers.
  5. bigheck
    bigheck
    Dec 27, 2006
    11
    how do i check my router settings to see if there's a "Client List", or "Wireless station" list ?
    thanks
  6. bouncer
    bouncer
    Dec 27, 2005
    3,604
    Glasgow
    +256
    As far as I know 192.168.0.1 or 192.168.1.1 or 192.168.2.1
