baldrick
A search yields 0 threads/posts related to this product and it's a bit of hybrid so this thread might need to be moved!?!?
I've just been looking at storage options on the Iomega website and come across of the Screenplay Pro:
The Iomega ScreenPlay Pro Multimedia Drive 500 GB allows you to easily play stored movies or music and view digital photos directly on your home television or while traveling. It produces high quality video and audio and with fast USB 2.0 transfer speeds and hot plugandplay, the ScreenPlay Multimedia Drive is convenient and easy to use.
According to the tech specs it can output 720p over component and supports Dolby Digital and DTS passthrough via optical or coaxial SP-DIF and it will play back MPEG1, MPEG2 (AVI, VOB, ISO),MPEG4 (AVI, DivX, DivXVOD, XviD) along with assorted audio formats!?!?
It has a 500GB drive on board plus Firewire400/USB2 connection to a PC to add/remove content....
All of this for £200, how come no one else has mentioned it on here?
