iomega eGo portable drive is read only, how do i change this?
Discussion in 'Apple Forum' started by kazino21, Nov 29, 2010.
  1. kazino21
    kazino21
    Mar 6, 2006
    681
    +5
    I've been using it on my other windows computer for a couple of months. Naught wrong with it, but when I put it on my mac air it is read only? Tried every menu I can find, but no idea how to make it writeable.
  2. slattery69
    slattery69
    Dec 9, 2007
    95
    +11
    its probably been formatted in ntfs which mac s can only read not write to without third party software.
    youll need to either format it to fat or the mac standard or create a partition on it so you can use it with the mac
  3. dc8900
    dc8900
    Dec 31, 2009
    12,259
    London
    +2,498
    as slaterry69 has pointed out, the drive is most like in NTFS while OS X uses HFS+, if you want the mac to write natively to that drive, you will need to (first save the data on the drive) format it to FAT so that both the Windows and OS X can write to it (but each individual file can be no larger than 4GB)
    Finder>Utilities>Disk Utility
    Of course, if you no longer have a Windows machine, you can format it to HFS+
  4. CamFire
    CamFire
    Apr 26, 2009
    4,707
    Cambridge
    +600
    More information re filesystems for the MacOS here.
    Yep, the ext HDD will need to be re-formatted (losing your data!!) by MacOS. Note that 10.6.5 (latest) supports exFAT - and the 4GB per file limit is gone.
  5. dc8900
    dc8900
    Dec 31, 2009
    12,259
    London
    +2,498
    I completely forgot about that :facepalm:
  6. kazino21
    kazino21
    Mar 6, 2006
    681
    +5
    is exFAT compatible with windows 7? So that I can use the drive on both my mac and windows machines.
  7. dc8900
    dc8900
    Dec 31, 2009
    12,259
    London
    +2,498
    yes, it was originally introduced by Microsoft
  8. kazino21
    kazino21
    Mar 6, 2006
    681
    +5
    So just use xfat and then it's cross platform and I'll have no issues with max file size?
  9. dc8900
    dc8900
    Dec 31, 2009
    12,259
    London
    +2,498
    you got in one bud :thumbsup:
  10. goonerfromlag
    goonerfromlag
    Feb 8, 2006
    378
    London
    +14
    simply download ntfs mounter, works like a charm & free
