Inwall speakers any ideas?
Discussion in 'Home Cinema Speakers' started by pacemaker, Dec 24, 2004.
  1. pacemaker
    pacemaker
    Aug 31, 2003
    565
    +17
    building a new house and cinema room smaller than before
    used to use 2 pairs of ma fxi's before for 7.1 surround
    still undecided about 7.1 in a small room didnt seem to make much diference before so may give it a miss this time
    anyway thinking of inwall design for rear
    construction is going to be block wall so dont know if its possible?
    anybody using them if so what?
    would quality be as good as fxi's?
    what sort of height?
    what about ceiling mount?
    cheers guys for any advice
  2. Wannabe-THX
    Wannabe-THX
    Apr 7, 2004
    240
    Putting the size of the room might help, and what equipment you already have.
    Fish
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    suggest you take a look at sonance in walls... download manuals and mounting instructions for a better idea of where they can be mounted and the depth needed.....http://www.sonance.com/
  4. pacemaker
    pacemaker
    Aug 31, 2003
    565
    +17
    thanks i'll take a look
  5. bobbypunk
    bobbypunk
  6. Tejstar
    Tejstar
    Dec 4, 2002
    22,808
    London
    +1,081
    Don't Quad do in-wall speakers too?
  7. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,709
    The Borders
    +3,076
    Pacemaker
    Add Atlantic Technology to your list of possible candidates - they have a range of In-Wall (THX, Non THX and Sub) along with In-Ceiling, On-Wall and Floor Mount to enable a coherent sound even with a mix and match installation.
    It may also be worth considering spending £150 on having your room Acoustically 'modelled' to find out where best to 'install' any hidden speakers before you make any costly mistakes!
    See http://www.atlantictechnology.com/ and http://www.homecinemaengineering.com/
    Best regards
    Joe
