Invisible Speaker Cable
Discussion in 'Cables & Switches' started by garyc, Oct 10, 2003.
  1. garyc
    garyc
    Dec 21, 2002
    895
    Jersey, Channel Islands
    +14
    Has anyone any experience of very thin speaker cable that are either wall papered over or painted for use with rear speakers?
    cheers
    Gary
  2. IronGiant
    IronGiant
    Jun 7, 2003
    61,662
    Oxford UK
    +38,482
    I got some of the Accoustic Research stuff from Maplin (I think it was branded Ross), but they may have stopped doing it. It works very well, but if you're just painting over it it will show depending on how the light falls. I taped over it with 2" wide white insulating tape and then painted that, which softened the edges a bit and does make it invisible to casual observers. Under patterned wall paper I think it would be fine.
    HTH
    Dave
  3. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    www.beyondhifi.net used to do that stuff as well, but have stopped too, I believe. I think CPC still do it, but it's very expensive (certainly compared to how much Beyondhifi used to do it for).
  4. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
  5. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    Yup, that's the stuff - remember to add VAT to the price.
  6. garyc
    garyc
    Dec 21, 2002
    895
    +14
    thanks for the info
    Gary
