Invisible sound card
Discussion in 'Computer Components' started by shodan, Sep 19, 2004.
  1. shodan
    shodan
    Dec 11, 2001
    11,707
    shoeburyness
    +6,809
    Bit of a complicated one here... A while ago my computer had a nasty virus which ended in me having to do a System Restore after the advice of HP who built the machine.
    Since then, my sound card hasn't worked. The computer knows what it is and what it does and it's listed in the Sounds and Video bit but the option for choosing a sound playback device is greyed out.
    Anything to do with audio results in the computer telling me things along the lines of "There is no sound device attached".
    I've checked all the drivers and codecs and they are all up to date and I've done just about everything else I can find and think of and now I'm at my wits end!
    Any of you clue-ed up computer folks able to help me?
    It's about a 20ft drop from the window to the floor so I really don't think any part of the computer would survive that....
  2. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    23,395
    2
    In a secret location with Jennifer Lawrence
    +10,337
    Have you tried removing the sound card and putting it in a different slot?
  3. shodan
    shodan
    Dec 11, 2001
    11,707
    shoeburyness
    +6,809
    I even took it out completely and uninstalled it and set the machine to use the on board one but it still isn't letting me choose a playback device!
  4. shodan
    shodan
    Dec 11, 2001
    11,707
    shoeburyness
    +6,809
    Anyone?
  5. ReggieDaMole
    ReggieDaMole
    Aug 18, 2004
    189
    19
    The fields of Anfield Road
    Can you get your hands on a copy of XP (home or prof) Do a new install. The system rebuild is an image which sound like is not completely adjusted for your hardware. A fresh install of XP will find all your hardware (more than likely) and if not, new drivers are available from HP.com.
  6. Brogan
    Brogan
    Oct 9, 2003
    7,582
    Cary, North Carolina
    +482
    Did you put it back in the same slot though?
    I have had similar problems in the past which could only be solved by putting the card in a different slot.
