Inverto Idl 7000t
Discussion in 'Digital TV & Video Players & Recorders' started by c h f, Sep 1, 2007.
Tags:
  1. c h f
    c h f
    Sep 1, 2007
    294
    LIVERPOOL
    +7
    I have been reading with interest the pros and cons of which pvr to buy, having almost decided to buy the INVERTO I was surprised that it never even got a mention in the discusion forum, does any one know of a reason for this? ----COLIN.
  2. 12 promises
    12 promises
    Aug 18, 2004
    1,555
    2
    dunfermline
    +119
    not really,...........i have one and it does the job very well except for the digital out which either does not work with some amps or has a limited success with others.
    if you really need digital sound out then best to stay clear.
  3. c h f
    c h f
    Sep 1, 2007
    294
    LIVERPOOL
    +7
    Hi I am glad I have found an owner may be you can answer this question for me can I hook it up thro` my cable box too record cable chanels? cheers, Colin.
  4. 12 promises
    12 promises
    Aug 18, 2004
    1,555
    2
    dunfermline
    +119
    i dont think so but not sure.
    i will dig out the manual later and let you know:)
    have to go out for a while.
  5. nwhitfield
    nwhitfield
    Dec 15, 2005
    1,628
    83
    +238
    No, you can't. The Inverto is just another box for Freeview only, built on the same 4TV software as several others. It will only record from its built in tuners.
  6. 12 promises
    12 promises
    Aug 18, 2004
    1,555
    2
    dunfermline
    +119
    yep absolutely correct.
