inverto high gain or alsat dark gold 0.1
boxer29
can some one hlep me in deciding a good quality lnb ,,whats the best out of the two ,,or any better then these two
i live around batley ,yorkshire ,,
want to put a80 cm solid dish ,,
watch hotbird and other satellites
2
which motor would you recommend
a superior dark motor ,,or the technomate 2600 ,,dont bother about the price diff ,,which will work well ,without any backlash etc etc
thanks
ABARKIE
I would say the inverto, had them both and found the inverto better
thanks
The dark motor is probably the better of the two when I had one, but have you looked at a superjack?
nolia
Inverto for me. Quality lnb. Im using one right now
boxer29
thanks
all
i went for superior dark motor ,,
might try superjack next time ,,if this doesn't work ,
this was not even on my list
hmm lnb still deciding will try the one which i have and see ,more inclined to inverto ultral high gain 0.2db is this the right one for me
Podcast: New Denon AV Products, HDMI 2.1, 8K, DTS:X Pro Sound Q&A with Denon Product Specialists
