As far as I can see there are no comparable published specs available so any comparison will be based on guesswork, depending on who is doing the guesswork will determine whether it's an educated guess or not
I'll give you my take anyway and we'll see where that goes.
The 6000 is a pair of 3000 amp modules where that number is based on some unpublished burst/peak rating. They also give RMS ratings as 2.2kW into 4ohm.
This benchmark shows it ~2kW per channel both driven at 4ohms on a 33% duty cycle at 1kHz & 1.8kW under the same conditions at 31Hz.
2 things I noted from that benchmark
* it is pulling a peak current of 80A in that 33% 4ohm 31Hz test, I don't see how this is applicable to a home setting so surely the sustainable peak power will be less at 1.8kW at home?
* the 33% duty cycle is used as "safe for pro use" whereas 12.5% would be "normal" for home use
In contrast, Focux publish a number based on a much shorter, higher frequency burst. Best guess, given that behringer don't publish where that 3000 number comes from, is that this number is equivalent to the 3000 number assigned to the inuke. On this basis, the focux (bridged 4ohm) gives 20% more power than an inuke 6000. If this is sustained down to the more onerous conditions the inuke has been benched at then you would get 2.1kW out of it on power draw alone.
Having said all that, the power you actually need is a function of the SPL you want to produce and the low end boost you need to apply to get there. I have neither the kit nor the experience to safely load test an amp/driver so I can only go by a WinISD model. Note I am a WinISD noob so this could be a Q of a little knowledge being dangerous.
My LT looks like this, i.e. it reaches +7dB at 10Hz.
+7dB is about 5x the power so lets conservatively assume the real power in the Focux is less than 1/2 the rated spec at 1.5kW and then divide that by 1/5 to account for the LT. This gets us down to 300W in WinISD, this gives me the following excursion chart. If I push this up toward 500W (equates to saying the focux can do 2.5kW) then I breach xmax.
