Intrigued by a Plasma
Discussion in 'Plasma TVs Forum' started by simon33, Mar 2, 2005.
  1. simon33
    simon33
    A friend of mine just bought the LG RX11.
    When the plasma is on standby you can see a small red light inside the set, looking down through the tv from above - the light does of course turn off when the tv is turned off at the mains.
    I am just intrigued by what (if any) purpose this serves, and thought the best place to ask would be here!
  2. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
  3. RichardHannan
    RichardHannan
    I have a home computer with a ged/green LED in the graphics card inside the system box - according to the manual it is for diagnostic purposes when assembling the computer.
    Could be the same for other hightech equip. such as plasma tvs ?
  4. googlybear
    googlybear
    Nov 10, 2004
    169
    16
    I would have thought that it is a status LED to show whoever is working on the equipment that there is still a live connection to it, if you switch off at the mains you will probably find that the LED goes out after about 10-20 seconds as the capacitors discharge.
  5. alscds
    alscds
    its actualy a transmitter that is planted by the goverment inside every tv set when the tv is in use it stores information then when the set is turned off it transmits it to a goverment agency where the information is then anylised it lets the goverment know if the dvd,s you are watching are originals or copies it can also tell them if you are using a chipped sky/ntl box then one day theres a knock at your door you get taken away and your family never see you again. so remember always turn it off at the mains. :thumbsup: :rolleyes:
  6. Rambles
    Rambles
    Jul 14, 2004
    10,442
    167
    UK
    +2,151
    I have just read something about plasma's having 'impact sensors'?
