Quantcast
Intervideos Home Theater 2 and Toshiba P25-S670
X
xy16644
Hello All!
Has anyone used Intervideos Home Theater 2 package as the software for their home cinema?
Does Leadtek Winfast UBS II work with this package? (I tried emailing Intervideos support but no reply...;-()
Has anyone used the component video outputs on the Toshiba P25-S670 laptop? I would like to run this to a Sanyo PLV-Z2 projector and was wondering how the picture will look.
Which would look better on the Sanyo PLV-Z2 projector, using a component output from a computer or DVI?
Which is better, DVI, RGB or component?
Thanks SO much! ;-)
