Interpolation of low definition sources
Discussion in 'General TV Discussions Forum' started by satwar, Jun 14, 2005.
  1. satwar
    satwar
    I read that HD LCD & Plasma displays are very poor at interpolating conventional definition signals compared to HD CRT displays.
    Can someone explain why they are inherently poorer?
    Thanks in advance for your help.
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Got a link to where you read that ?
  3. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    CRT's are not fixed resolution displays, they use scan lines that can adjust to a number of resolutions. So they do not have to interpolate the incoming signal to fit the screen. Also, most plasma and LCD are inherinently progressive in nature so they need to deinterlace interlaced signals. Deinterlacing and scaling can be done very well, but it can also be done badly.
    -Ian
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,243
    The Borders
    +2,941
    Hello satwar
    Like most things I guess the answer is Money - or lack of it :)
    If your producing a High Resolution Display I guess you'll assume most end users will be using a High Definition source and there's no sense is specifying and spending big on a really high quality processor to scale and map low resolution signals to your high resolution Display.
    Step forward the various manufactures who do offer very decent external processors that can be programmed to convert any number of disparate standard definition signals and output a pixel mapped signal to Input to your HD Display.
    Best regards
    Joe
    PS Not all HD Displays are bad at handling SD sources.
