ChuckMountain
OK, thanks for that.
Re reliable speed test from your previous post, I don't have Netflix, is there an alternative that you know that I could use?
They all seem to be very hit and miss with TVs. There is Internet Speed 2 I think in the LG store but even that is rubbish and I find all over the place.
The problem is that a lot of the speed tests spin lots of connections up to try and go faster and max your bandwidth, which is fine on a computer but not great on a TV. The TV just needs one single fast enough connection to stream UHD at around ~25Mbps or so.
Are you noticing any issues streaming TV? What Apps\sources do you use?
