Internet Media Centre Help!!!
D
ddk121
I have a Packard Bell new pc I have media center edition 2005 on it. I am tryng to download the guide but having problems when it comes to the Connecting to Internet bit. After about 3 minutes, it says something like 'an unknown error occured.' I have my computer connected to a wireless router, I have aol broadband, And I have Nortion 2006 (which I also have disabled to see if it works).
Help much appreciated!
G
Gadget_Man
I'm having the same problem and very interested in the solution. BTW i am also using AOL.
markxtc123
Three quick questions.
1) Can you access the internet using IE on this machine?
2) Are you certain that the clock is set to the correct time and date?
3) Are you certain your location is set to the UK?
Mark
G
Gadget_Man
Sorry, don't mean to hijack but see below answers.
My pc has the correct time/date. Is set to uk. I can browse the intenet fine via IE.
G
Gadget_Man
Error does not return an actual code it just says no internet detected when trying to download the EPG or detect on the initial MSE setup.
However Event Viewer is giving:
Event Info: An unknown connection failure occurred. Media Center was unable to connect to the Internet. See Help for more information.
Process: DefaultDomain
Object Name: Microsoft.Ehome.Epg.Ehepgdat
