Internet Explorer 7?
Discussion in 'Computer Software & Operating Systems' started by pauls898, Dec 18, 2006.
  1. pauls898
    pauls898
    Jun 14, 2006
    193
    +7
    Anyone upgraded to Internet Explorer 7 and found thier graphic and text looks burry?? as if its got smugged
  2. Big Bert
    Big Bert
    Jun 2, 2004
    274
    +21
    Hi pauls898,
    What you are seeing is Clear Text. Here is an explanation:
    Why do fonts look blurry in Internet Explorer?
    If screen fonts look different in Internet Explorer than they do in other parts of Windows (for example, if they're blurry or bolded), it might be because because of ClearType. ClearType is a software technology developed by Microsoft that improves the readability of text on Liquid Crystal Display (LCD) monitors, such as those used on laptops and flat panel screens. ClearType can sometimes appear blurry on Cathode Ray Tube (CRT) monitors or un-tuned LCD displays. By default, ClearType is always turned on in Internet Explorer, regardless of how Windows is configured, though you can change it.
    If your fonts are not displaying as clear as you'd like, you can try optimizing ClearType for your monitor. Go to the Microsoft Typography ClearType (http://www.microsoft.com/typography/cleartype/tuner/Step1.aspx) website, and then follow the instructions for tuning ClearType. The website installs an ActiveX control to help you tune ClearType to your monitor, or you can download a tool that can be used offline instead.
    If you still do not like the how ClearType looks in Internet Explorer and you want to turn it off, follow these steps to have Internet Explorer use the same settings as Windows. Once you do this, you can turn ClearType off (or back on) by using the Windows Control Panel.
    To have Internet Explorer use the same ClearType settings as Windows
    In Internet Explorer, click the Tools button, and then click Internet Options.
    Click the Advanced tab, scroll to the Multimedia section, clear the Always use Clear Type for HTML check box, and then click OK.
    The changes will take effect the next time you start Internet Explorer.
    Hope that helps.
    Gordon
  3. pauls898
    pauls898
    Jun 14, 2006
    193
    +7
    Thanks Gordon
    Sorted Thanks, was neally gona see if my graphics card had gone wrong lol
    Thanks again for such a quick responce
    Cheers mate
