internet drops when using ICS
mattg
Hi there,
Having a bit of headache with my xbox and the guides do not seem to solve the issue.
this is my router setting
when I enable ICS, I am still connected to the wireless network, but I lose my internet connection. If I untick all the boxes on the right then it still doesn't work.
I get this message pop up, and the internet connection icon disappears in the networking connections page:
troubleshooting
If your wireless card will not connect to the internet even after a reboot. Follow this great guide here to force the card into promiscuous mode.
If you are still having problems and want to revert, just delete the bridge icon.
I get this when typing "netsh show bridge" in cmd prompt and so am not sure what to do next to force my card into promiscuous mode:
the router is a netgear DG334GT 108mps wireless router, the wireless card is belkin 54g.
I have tried to set a manual ip adress on the xbox of:
192.168.0.90
255.255.255.0
192.168.0.1.
but still have the ip address fail when I run the test. I can see media from my pc so the cable seems ok.
Does anyone know where I am going wrong?
Thanks, Matt.
mattg
EDIT:
Problem solved, I had not read the promiscuous guide correctly and have now forced my wireless card to enable it.
to get it working I had to:
bridge wireless card and network connection
(internet drops)
start>run>cmd
type "netsh bridge show adapter"
find number allocated to the wireless adapter the use it below
type "netsh bridge set adapter 1 forcecompatmode=enable"
Apparently a lot of the wireless adapters have a problem bridging.
This has solved the ip conflict, the xbox is now set auto ip and works a treat.
I hope :D
ShadowmanUK
Yeah, the ip conflict was because netgear routers use the same address as ICS. But then.. ICS is not the best to use anyway in that setup.
Glad you sorted it anyway :clap:
mattg
yep I am quite impressed with myself. Although I have lost a morning to it though.
*stupid technology grumble grumble*
