Hi peeps,
I need some help with regards to my internet connection. I can be surfing the net for a while and all will be well. Other times my dongle can turn of by itself losing me the connection. And others my connection can be dropped, reconnect, drop, reconnect then drop and reconnect again.
I have had problems before with my Laptop (Vista) saying I was connected to a "Virtual Profile" which caused similar connection issues. I found a thread saying that some dongles (mine) have problems connecting with vista and the best way to resolve it was to re-install the software yet don't let it install completely, and then set up the connection using Network And Connections. This is what I have done and yet I still get some issues but not the Virtual Profile problem.
I am using a Netgear Rangemax router and a Netgear Rangemax WPN111 dongle. I can be sat with my Laptop on the arm of the chair with the dongle about 10inches away from the router and still have problems.
I regularly reset the modem and router, scan for viruses etc and yet I am now stuck as to what else to try.
Any help/suggestions would be greatly appreciated.
Thanks in advance.
Thanks in advance.
