Internal tuner specs???
Discussion in 'Projectors, Screens & Video Processors' started by hornydragon, Jun 11, 2003.
  1. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    What is the Video output used by an internal tuner in analogue and IDTV's?????????
    Is it RGB or what, I just wondered how it compares to external sources like DVD etc and with STB boxes using RGB S-vid etc but what the hell does the internal one use???
  2. They
    They
    Sep 10, 2002
    171
    16
    Bristol
    Most likely component YUV.
  3. salacious
    salacious
    Nov 2, 2001
    46
    Scotland
    IDTV's like SKY and DVD use MPEG-2 which is a YUV format. Analogue TV is a composite broadcast signal. This is colour (UV) is seperated from the signal thus leaving the detail (Y). This information overlaps and this is why you get effects like cross colour and dot crawl. It can be improved with comb filters but it will never be as good as seperated component signals.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Cheers guys.
