Internal Speakers + Surround Sound and Sub problem LG Oled 2020
fi70
I have an LG GX TV (2020) which I have managed to mount on my wall with not a single cable visible (all routed behind the wall). It looks great, and also sounds great. Or at least, sounds good enough, that I don't want to clutter my perfect smooth viewing wall with any speakers or soundbar. The internal speakers are plenty loud enough for the room where I have it. However, I would like some surround speakers each side at the back of the room, and a sub-woofer somewhere out of sight. I cannot figure out a way to solve this. I really need your help!
1) WISA - there is no way to use WISA without disabling the internal speakers
2) HDMI - (eARC or otherwise) I don't think there is a way to get a signal without disabling the internal speakers (please correct me if I am wrong!)
3) Optical - I CAN get an optical signal without disabling the internal speakers (Setting = "Internal Speakers + Optical", interestingly it is also the factory default) BUT I can only get 2 channel sound out of the optical link in that mode (so not helpful for surround, but maybe work for sub..?)
4) Bluetooth - Conflicting information about whether the output is actually "surround" or just a stereo output. I have yet to test this, but am planning to. Even if it is some sort of "surround" it doesn't solve my sub-woofer problem.
Having made the investment in the TV(!!!) I'm quite happy to spend a bit to solve the sound issue... It seems strange that LG didn't think about this, given how awesome the TV looks with a clean install on the wall.
While I have the LG GX 77 2020 model but I think this problem is common to the CX and other models. But perhaps you have to have the GX to care about clutter at the front!
New to this fourm as a poster but very appreciative of all the help I have found here so far.
JayCee
Forget about using the internal speakers and a surround system at the same time...it's one or the other.
The sound will be out of sync if you try to use both.
fi70
Well - with the Bluetooth option you can delay the Internal Speaker sound until it matches the Bluetooth - why couldn't LG make that available on more combos?
fi70
Hi @JayCee - solved with the bluetooth option. I have a Bluetooth amplifier under my couch, which feeds the left and right surrounds (and the signal is actual surround, not just R & L mix). The amplifier drives those speakers directly and also has a passive sub out which I use to drive a BlueSound Pulse+ Sub under the couch. All hidden, great sound quality and no lags - all in sync! I can recommend this type of solution for anyone else not wanting to clutter up the wall around a gallery mounted LG OLED.
Podcast: Hisense A7G, Zidoo Z1000 & Kudos Cardea C10 Reviews + Movie News and Reviews
