Internal paralell connector for VFD
Discussion in 'Desktop & Laptop Computers Forum' started by smallangryboy, Jul 13, 2004.
  1. smallangryboy
    smallangryboy
    May 5, 2003
    1,940
    +73
    I'm looking at the Accent case HT400. The supplied VFD is a parallel connector. However it has to route outside the case and plug into the parallel port.
    Is there a way of making the parallel port internal or adding an extension cable to the parallel port inside the case, from the MoB ?
    cheers
  2. Kramer
    Kramer
    Are you sure it's parallel? Not serial?
    If it's serial you could use a usb/serial adapter & connect to an internal usb header.
    :smoke:
  3. wyerd
    wyerd
    Dec 29, 2000
    761
    28
    Upstate New York. USA
    +27
    I have the HT400 - it's a parallel VFD.
  4. ian_guinan
    ian_guinan
    Apr 14, 2001
    1,164
    38
    Australia
    +18
    I bought a card at a computer fair for my Accent case which has 2 serial out and one parralel port which comes off the pci card on a cable. One day (sigh) I'll get round to working out the pinout and making a cable to go direct to the vfd...till then it is held in place with cable ties.
    I'll try and find out the make/model no. of the no-name card.
    Ian Guinan
  5. ian_guinan
    ian_guinan
    Apr 14, 2001
    1,164
    38
    Australia
    +18
    Here's something similar;
    parallel card
    Hope this helps...
    Ian Guinan
