Internal MCE IR Receiver & Sender
oublie
I've got a Zalman hd160 which comes with an internal ir receiver but does not have an attachment to sent IR signals to my sky box or any other external IR equipment. Is there an internal IR receiver with a sender available as I am currently using the Microsoft one in order to change channels on my sky box and would ideally like to make it all incorporated into the box. Secondly i'm building a second Media centre and would like to incorporate this device into it rather than going the external ir receiver / sender route. What i'm thinking is something with a front panel receiver with a pass through connector on the a back plate to allow the sender to be attached.
Thanks.
T
tim_kay
Not sure if I understand you completely.
Are you using a pvr150 card to control your sky box?
If so I'm sure you'll realise the ir extender has to sit right ontop of the ir receiver on the stb, so no way you'll get it internal. You will still need the usb receiver connected to ir extender.
Samsung S95B QD OLED Review - A Quantum Leap for OLED!
