Intermittent momentary transmission breaks on Loewe Xelos TV
Discussion in 'General TV Discussions Forum' started by alunevans, Mar 17, 2005.
  1. alunevans
    alunevans
    Mar 17, 2005
    24
    I have just connected a JVC S-VHS to my Xelos receiver and, possibly coincidentally, the TV picture and audio signals are now subject to intermittent momentary (approx. 1 second) interruptions, in which the sound mutes and the picture blanks totally. The picture and sound then resume as normal until the next 'break'. I have tried disconnecting the video and find the reception problem persists, even when the video is bypassed completely. Has anyone experienced similar problems with this or any other TV? (The transmitter mast is operating normally, by the way.) :lease:
  2. JayCee
    JayCee
    Jan 20, 2004
    24,003
    Lanarkshire
    +2,618
    If you have Sky or a dvd player watch it via scart..........if that is not affected it is likely the tuner in the Loewe is at fault.
  3. alunevans
    alunevans
    Mar 17, 2005
    24
    Thanks, JayCee. I think it must be the Loewe tuner, as you suggest, - playback of video input via SCART is unaffected by breaks. Engineer due tomorrow to check things out! :smashin:
  4. Tight Git
    Tight Git
    Mar 3, 2004
    6,331
    +597
    Alunevans,
    Just a thought:
    If you've been fiddling with the rear connections, have you perhaps disturbed the aerial feed?
    (Give it a wiggle!).
  5. alunevans
    alunevans
    Mar 17, 2005
    24
    Dear TG
    Yes, I've given all the conectors a wiggle (!!) without success. The engineer came earlier to day and took the set away for testing. (Fingers crossed!) :smashin:
