Thedoctor22uk
Hi everyone,
I've got a minor issue, which I'm finding quite irritating. Hopefully you geniuses can think of a solution!
I recently upgraded my TV and av receiver (samsung qe55q90t & yamaha htr2071).
Occasionally there seems to be an issue where the receiver doesn't put the sound through the surround speakers and the sound from the input(sky/ps4 for example)comes through the tv. This normally when first turned on.
I essentially have to turn the receiver off and on again to get it to come on. Which solves it. Its a minor inconvenience but grates me, no end!
I'm using arc. Everything is in the correct ports. Arc is turned on both the receiver and TV.
8 times out of 10 its fine. Is it a setting I perhaps have got wrong, or a hardware issue?
Appreciate any input!
Thanks in advance!
Thanks in advance!
