DJ007
Hello.
Up until yesterday my aerial was connected directly to my Pioneer LX60 and then fed to my CRT. The picture was great although at times it would jump/distort notably on every channel apart from the BBC ones. This would happen regularly but it would go through periods of days without breaking up.
Since I've installed my Pio 428 the problem has heightened. When I connect the aerial directly to my TV the picture is great and doesn't distort on either analogue or digital. However when I connect it to my LX60 it will only pick up BBC channels.
Since it has only happened to this degree since I've moved my equipment could my aerial lead be effected my power cable/speaker cable?
Would investing in decent aerial cable/booster box make a difference as I'm using a crappt 1mtr run of cable!?
Thanks.
Thanks.
