Intermitant "Live TV" Fault
sapper
Please help...
The lst few days, my Media box has being playing up. In particualr MCE Live TV will not load a TV channel, but after a reboot, it may.
It is intermittant but still annoying. Recorded TV, DVD ets all seem to be fine, its just Live TV that can be at fault.
Any thoughts?
Adrian
sapper
Slinkoff said:
it's the weather
Seriously how so. The reason I ask is that it seems to work in the morning but not the evening.
Last night when I pressed live TV, the 'rotating arrow icon' moved for a while and stopped. Tried rebooting hte PC, rescanning but no change.
This morning I switched on and on the second attempt, it worked, the last tiem it worked was Thursday morning.
This is wierd, but if it doenst alm down, a re-install might be called for, with the time hassles that invovles.
Adrian
nigelbb
It's the hot weather. Your signal is marginal which is causing your probelms. You may need a new, decent aerial or may get away with a chaepo signal booster.
