Interlacing only on lower half of screen?! Nuts!
Discussion in 'Plasma TVs' started by simonpickard, Feb 1, 2005.
  1. simonpickard
    simonpickard
    Feb 1, 2005
    Hello all,
    I have just got a new NEC 42VR5W 42" plasma screen and have noticed a weird problem with it.
    There is a lot of interlacing (some lines moving slower than others) on moving images (reds and skin tones mainly) but this is only happening on the bottom half of the screen. I understand that plasmas do have slight problems with moving images and ghosting but, and I see this very slightly on the upper half of the screen, but the lower half really looks like it's out of sync. I would also expect the whole screen to act this way if that is how it should be.
    Could you please advice what I should do about this?
    Regards,
    Simon Pickard
