Interlaced RGB Scart to Progressive YUV Component
Discussion in 'Plasma TVs Forum' started by BrianC, Aug 21, 2003.
  1. BrianC
    BrianC
    Jan 20, 2003
    2,199
    +101
    does anybody know if its possible to take the PAL interlaced RGB (via a scart socket), and have a deinterlaced YUY component output?
    Basicly I want to make my Sky+ box output prog scan to my tv via component (it only support prog scan on component)
    Any links to a recommended product or even just letting me know that its possible would be most appreciated.
    thanks in advance,
    Brian
  2. tbrar
    tbrar
    May 31, 2003
    609
    16
    BrianC,
    Sound like you need an RGB-YUV Converter, but will also need a deinterlacer to turn the Sky into progressive format.
    ISCAN Ultra should do the deinterlacing to a high quality and JS Technology converter will do your RGB-YUV.
    Have a look at www.tmfsolutions.co.uk , if you can put a call into Joe Fernand - I beleive he sells both and will be able to advise.
    I am not aware of an all in one solution that will deinterlace and perform RGB(Scart) to YUV conversion, hence the two products.
    Tony
  3. BrianC
    BrianC
    Jan 20, 2003
    2,199
    +101
    Thank you very much for the reply, it looks like what I need, if a little more than I org budgeted for :p
  4. GAmbrose
    GAmbrose
    Jul 5, 2003
    1,000
    63
    Essex
    +185
    Wow, didn't realise Sky+ box could output a progressive scan image.
    Gary A
  5. tbrar
    tbrar
    May 31, 2003
    609
    16
    Gary A,
    I dont think it can, his TV will accept PS through component.
    He wants to feed Sky in progressivly to the TV, hence needs a deinterlacer and a converter to deliver a progressive scan signal, through these inputs.
    Tony
  6. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    The iScan Ultra and JS-Tech RGB2YUV convertor give an excellent progressive scan picture from Sky+'s RGB output.
    Sky+ picture can be further enhanced by ordering one of Mark Grant's power cables.
    StooMonster
