interlaced or progressive?
Discussion in 'Plasma TVs Forum' started by kwijibo, Nov 27, 2004.
  1. kwijibo
    kwijibo
    Feb 4, 2002
    475
    essex
    I have my Pioneer 757 DVD set to progressive, but when watching DVDs and pressing 'display' on the remote for my 43MXE1 plasma, it says 625i.
    Is that right?
  2. mcav
    mcav
    Nov 11, 2004
    456
    +58
    Pretty sure the i is for interlaced.
    and a p would be for progressive.
  3. kwijibo
    kwijibo
    Feb 4, 2002
    475
    essex
    thats kind of my point. What have I done wrong?
  4. mcav
    mcav
    Nov 11, 2004
    456
    +58
    It must be product specific but I am sure you're screen must be set up to display interlaced as oppossed to progressive.
    Your player is outputing progressive scan, but the screen may be displaying it as interlaced.
    This is only a guess, but I'd imagine there is a setting in the screen which says to accept a progressive scan feed.
    Maybe????
  5. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Silly question I know, but.... are you feeding the TV with component video (i.e. Y, Pr, Pb ) ?
  6. kwijibo
    kwijibo
    Feb 4, 2002
    475
    essex
    yes, the DVD player is outputting component
  7. kwijibo
    kwijibo
    Feb 4, 2002
    475
    essex
    Is it to do with PAL or NTSC? Maybe my DVD doesn't do PAL progressive? Anyone?
  8. MarkB4506
    MarkB4506
    Nov 16, 2002
    Glasgow
    +4
    That may well be it.
    Plasma screens cannot display interlaced images - the reason for the onboard deinterlacer - so 625i means it's receiving an interlaced image which it then processes for display.
    When the 757 first appeared it could not output 625p. So if you see 525p when you play an NTSC disc then that could well be the problem.
    There was a firmware upgrade to enable 625p for the older machines.
  9. Ged
    Ged
    Apr 29, 2002
    938
    +24
    I have the 757 and it does PAL and NTSC prog scan, it came with an addendum to say some Pioneer plasmas cannot handle PAL prog scan.
    I am sorry, but I do not know which model, if I find the instructions I will post.
  10. Ged
    Ged
    Apr 29, 2002
    938
    +24
    Just checked, it refers to the HDE range.
  11. kwijibo
    kwijibo
    Feb 4, 2002
    475
    essex
    can any of the installers shed some light on this one?
