I have just had a 20x10 shed put up and I want some lighting for the inside. It does not have electric in there.
Does anyone have any suggestions on what I could do.
Thanks in advance![]()
Match..................![]()
Need more information, how big is the shed? apart from the obvious, what do need the lighting for?
The shed is 10x20 feet like i have said. It is about 50 feet away from the main house. I need the lighting just to see tools and things when I'm in the shed when it is dark.
Any other info needed?
Would battery powered LED lighting be suitable?
Get a qualified electrician to lay some armoured cable and have direct power ,at the end of the day your going to need more power than just lighting![]()
I've just put a concrete one up at roughly the same size (I keep calling it a 'workshop' to try & convince SWMBO I must be doing something useful in there) and had the same problem, so bought a solar shed light from Makro, which was about £20. It has 5 'tritronic' (whatever they are) LED's, and the solar panel is about 15cm x 20cm.
It is just about adequate enough to find tools & things, but not light enough to do any precise work by, such as drilling, measuring etc. But I don't think I have it in the best position, as I have it above the door, and could really do with being at the back (lowest) part of the shed.
It was very easy to fit, and obviously loads cheaper & easier than an electrician, so my plan is to buy another one the next time I go to Makro, and to reposition the one already in.
I ran an armoured cable and small consumer unit along with a couple of RCD sockets and a couple of 5ft IP65 rated twin flourescent lamps in my shed and this is more than sufficient. It did help that most of my materials were donated by my boss at work
You might need 4 lights to get a decent light level though in a shed that size though. If you know any decent electricians, buy the stuff yourself and mount everything to leave him to connect up and issue the cert.
The solar lighting might be a problem due to the lack of sun light! How much sun light do you get on your and how long does it last?
In the long run I maybe turn the shed into more then a storage space so I don't think solar is an option.
I may just go with LED battery powered lighting as it would be the cheapest at the moment.
I am tempted to get an electrician in but I think it is going to cost a lot, could anyone give me a rough idea on how much it would cost?
Have you thought about a car battery? you could run a couple of 12v lights from it and charge the battery up as and when.
Personally I would install armoured cable / small consumer unit etc (you are bound to want power as well as light eventually)
However there is nothing to stop you, assuming you apply some common sense, running a 50' extension cable to the shed - plug it in to an RCD in the house when you need light in the shed. In other words have the cable there all the time (running along a fence or whatever), but only power it up when you need it.
I have not got the best knowledge about electrical wiring but I have a consumer unit where all the electric wires in the house are connected, can I just connect a armoured cable to that and then run it down to the shed?
So do I need to connect a RCD? If so where does that connect...On my consumer unit there is already a switch which is labeled RCD.
Get a sparky in to get the job done properly and safely.
There is nothing wrong with you being there to help him with the install, but at the end of the day, its outside and there are a number of things that should be checked and installed to ensure safety, that most non sparks havent the slightest clue about.
Have a phone round your local ones to get some idea on price.
It wont be that cheap. most of the cost will be in the cable.
Yes there is something to stop you. It sounds like what you could class as a temporary installation. It's allowed but it must be checked every three months. I'm betting it never would be (or not by anyone qualified.). Extension cable is not really designed to be used permantly like this. Worse case scenario is that it's exposed to the elements and gets damaged by sunlight, frost etc, insulation breaks down, kid handles it, RCD fails to trip as it isn't periodically tested and it has seized, and you are in court explaining your dodgy wiring to an inquest. Do a proper job or not at all.However there is nothing to stop you, assuming you apply some common sense, running a 50' extension cable to the shed - plug it in to an RCD in the house when you need light in the shed. In other words have the cable there all the time (running along a fence or whatever), but only power it up when you need it.
