Intergrated TV advice please
Discussion in 'TVs' started by clanline, Jul 5, 2005.
  1. clanline
    clanline
    Jul 3, 2005
    64
    I am replacing my old Tv with a new 28 in widescreen and am a bit unsure whether to get an IDTV intergrated set or stick to separates (have a JVC set top box)
    I was told that if the freeview in an intergrated set goes wrong the whole TV will have to go back and on the other hand have been told that the picture is better with intergrated and it frees up a scart socket.
    HELP! : : : :
  2. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    Good points are slightly better picture quality with good TVs, easier to use, one remote in use, and saves an RGB Scart.
    Sony are a good make especially their 50Hz IDTVs
  3. JohnW14
    JohnW14
    Aug 6, 2004
    77
    Wiltshire
    If you already have a freeview box, get an IDTV. You will then have fewer remote controls around and can watch one FV channel while recording another.
    I would not recomment an IDTV only (i.e. no separate FV box) since generally you can only record in composite and have to leave the television on standby if you want to record something while you're away for the weekend.
    As for returning the whole TV if it goes wrong - rubbish if you have a halfway decent engineer. The digital side of my IDTV (Toshiba) went wrong and the engineer ordered a new digital board, took the back off the TV and plugged it in. Simple as that.
  4. TV Headache
    TV Headache
    Mar 3, 2004
    242
    16
    The combination of an IDTV and a Freeview PVR for recording is a great one. You can always move your existing Freeview box to another TV (or sell it!)
    I'd also recommend Sony IDTVs for picture quality, good EPGs and general ease of use.
